Considering dual loop.
10 Jan 2006
Newton Aycliffe
rebuilding my watercooling loop this weekend, just a passing curiosity really, got enough parts to work with here(would probably have to mount 2x reservoirs externally due to space), just wondering if it would be worthwhile, cant say i've had poor temps in the combined loop.
whats other peoples experiences with dual loops?
as it stands i'm probably just gonna stick with the combined loop unless i'm likely to see significant benefits, so far all i can see is isolating the heat of the GPU's from the CPU:confused:
It won't run any better, possibly even worse as you'll lower your delta at the rads.
Essentially you'll probably only see 1 or 2 degrees difference in temp across the loop and thats in an extreme case.
Only worth running dual loop if it makes the routing easier.
...its more likely to make routing worse with the space i'm working with and lack of a dual loop reservoir, only 2 single reservoirs.
on thinking about it, it would just be too much hassle.
scrap that just stick to tidying up the loop i have:D
