- 10 Feb 2026
- Turkey
Hi everyone,
First of all, greetings! I’m thinking of getting the Gigabyte B850M Force motherboard, but I have a few questions and wasn’t able to find clear answers online, so I wanted to ask here.
I plan to run Samsung B-Die RAM at 6000 MT/s or higher in 1:1 mode with this board. Do you think I’ll run into any RAM OC issues? I’ve never used a Gigabyte BIOS before, and if anyone here has a typical Samsung B-Die OC profile they use successfully, I’d be really grateful if you could share starting values that should work without hitting limits.
Also, I’ve read in a few places that Gigabyte’s entry-level B-chipset boards sometimes have restricted PBO and Curve Optimizer settings, possibly due to fewer VRM phases or lower-grade power delivery. Do you think I’ll run into this issue with the B850M Force? Has anyone used this board without problems?
Thanks in advance!
Thanks in advance!
