Hi,
I'm considering getting a new monitor to replace my aging (but still great) Samsung 2033rz. I have loved the smoothness of 120hz, so I want a monitor which is at least 120hz, and I want to upgrade to 1080p resolution. I also want to upgrade to at least 24", probably 27", and finally of course I want the best image quality I can.
So, my only requirements are:
120hz or above
1080p or above
24" or above
Everything else is negotiable. I don't really have a budget but I'd say around £400 is the maximum I'd spend.
I have been looking on OcUK and I've found a few which are worth thinking about:
BenQ XL2411T 24" - 1920x1050 - 144hz - 2ms - 269.99
Benq XL2720T 27" - 1920x1050 - 120hz - 1ms - 379.99
Asus VG278HE 27" - 1920x1050 - 144hz - 2ms - 359.99
Iiyama Prolite G2773HS 27" - 1920x1050 - 144hz - 1ms - 275.99
Acer HN274Hbmiiid 27" - 1920x1050 - 120hz - 2ms - 299.99
I'm pretty sure I want a 27" one but is it worth the price over a 24"? How is 1080p on a 27"?
I don't really see 144hz making much difference over 120hz, am I right?
The Iiyama Prolite and Acer ones seem far better value on paper, but I imagine the image quality isn't as good as the BenQ and Asus models? Or am I just paying for the brand?
Finally, are there are others worth considering?
Any opinions/advice would be appriciated
Thanks for looking.
120hz or above
1080p or above
24" or above
