Console Monitor.
22 Jun 2015
Hey guys,
I'm currently looking for a 4k monitor around the £300 mark as it seems to be impossible to find a 32" TV for 4K.
It'll be used only for my Xbox One X and PS4 Pro, so was hoping whatever it is you advised would take full advantage of these consoles.
I was aiming for between 28"-32" though smaller than 28" is fine also.
Nobody got any advice at all?
AOC U2879VF or Benq EL2870U. It also having Freesync to use with the XboneX
For bigger screens you need to add more money. Also if you are looking something bigger, Philips 43M6VBPAB
Yeah I was looking at the following.
BenQ 28 EL2870U
Samsung U28E59D
LG27UD58
But couldn't work out what would be best or most suitable for the XONEX
I've got the AOC U2879VF - Very good monitor for the price, would recommend if you sit relatively close to your monitor.
If you sit quite a distance away, you'll probably want something 32" or bigger.
