Console Problem C#
Don
5 Oct 2005
Liverpool
Ok here it is...
class Class1
[STAThread]
static void Main(string[] args)
// read and display the user's Internet Explorer start page
// open the registry key
RegistryKey rk = Registry.LocalMachine.OpenSubKey(@"SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall");
if (rk == null)
Console.WriteLine("Registry key does not exist.");
else
try
TextWriter tw = new StreamWriter("t:\\ComputerSoftware\\"+Environment.MachineName+".txt");
tw.WriteLine(DateTime.Now);
tw.WriteLine(Environment.UserName);
tw.WriteLine(Environment.MachineName);
foreach (string valuename in rk.GetValueNames())
rk.GetValue(valuename).ToString();
tw.WriteLine("Start page = {0}", valuename);
tw.Close();
finally
// cleanup
rk.Close();
but the its not working correct... its supposed to write in a text file all the displaynames in the unnstall registry directory...
Ideas?
Stelly
it'll be the extra space in the registry key that's breaking it ;)
Paul
edit iirc you are trying to get a list of all installed software in the machine? that's not the right place to look in the HKLM hive and I have a whole bunch of software installed on my development machine that doesn't make itself know in the registry
