First of all Ive had my PC for a year and I have never had a problem up until 2 months ago.
It first started when I changed the voltage in the BIOS to the CPU to 1.36 instead of AUTO. Yet after a while I decided to change it back to AUTO and it still gets the same problem.
I have checked the CPU on Prime95 for hours and It does not seem to BSOD at all.
It happens usually when Im using Flash on Chrome (Watching a video usually) or when Im in a game it can happen randomly (Yet this is more rare).
It defiantly not a software Issue I formatted my hard-drive and re-installed Windows 7 yesterday and I still seem to be getting these problems its almost random yet watching videos seems to be a correlation.
I went onto Blacklight retribution yesterday for the first time since my re-format and I got two blue screen's on the menu screens. I went into the BIOS and set the CPU Voltage to 1.37 and it seems not to be blue-screening for now.
My spec:
ASE: CoolerMaster Elite 310 Mid Tower Gaming Case with see-thru side panel
CPU: AMD Phenom™ II X6 1100T Six-Core CPU ***Overclockable S&S only***
Cooling Fan: Asetek 510LC / Xtremegear Liquid Cooling system w/ 120mm Radiator (Asetek CPU Water Cooling ***Overclockable XXX***)
MOTHERBOARD: ASUS M4A87TD EVO AMD 870 Chipset CrossFireX Support DDR3 Socket AM3 ATX w/ 7.1 Audio, GbLAN, IEEE1394a, USB3.0, SATA-III, RAID, 2 Gen2 PCIe, 1 PCIe X1, & 3 PCI
Internal USB/SATA Expansion Module: NONE
MEMORY: 8GB (2x4GB) PC10666 DDR3/1333mhz Dual Channel Memory(Kingston Hyper X Blu Series w/Heat Spreader ***Overclockable XXX*** )
VIDEO CARD: ATI Radeon HD 6950 PCI-E 16X 2GB DDR5 Video Card, Eyefinity 4 capable (Major Brand Powered by AMD)
Power Supply Upgrade: 850 Watts Power Supplies (CoolerMaster 850watt Silent ProModular Gaming Power Supply, SLI / Crossfire ready)
Hard Drive: 2TB SATA-III 6.0Gb/s 64M Cache 7200RPM Hard Drive (Single Hard Drive)
Optical Drive: 24X Double Layer Dual Format DVD±R/±RW + CD-R/RW DRIVE. (BLACK COLOR)
SOUND: HIGH DEFINITION ON-BOARD 7.1 AUDIO
LCD Monitor: 22 Inch BenQ G2222HDL
Headset: Turtle Beech X11
Network: ONBOARD 10/1000 NETWORK CARD
Keyboard: Cyborg Gaming Keyboard
Mouse: Gigabyte Mouse
Wireless 802.11B/G Network Card: PCI-E Wireless 802.11n 300Mbps Network Interface Card
USB Port: Built-in USB 2.0 Ports
Operating System: Microsoft® Windows® 7 Home Premium (64-bit Edition)
Any help would be appreciated.
My spec:
