Constant 'Connection Problem' in CSS?
Consigliere
12 Jun 2004
SW17
I have a BT Homehub (:rolleyes:) with a desktop and laptop connected to it using wires. I am always getting connection problems whenever i try and play CSS...sometimes it works, sometimes it doesn't.
Is it CSS being retarded or the Homehub? Any settings i can change to solve this?
Web browsing is fine and it still happens when there is only light browsing occuring on the desktop. (I'm on the laptop).
Ideas?
its steam!!!! even iff you try cs which I used to play a lot of it would kick me out every so often with a connection problem. I could reconnect easily but thats not the point, it all started around *** time of the traffic shapping, also ping maybe higher :(
I left BT & went to adsl24 & well I've never bombed since, BT said it was my router so I politely explained to the bloke reading from the cue sheet its not *** router its your traffic shapping & stated I've tested the following routers (about 7) including the hub.
All I can say for you is check the advanced settings in *** hub & allow HL2,Steam or try another router & if that does not fix it its BT TBH.
