Guys,
The Mrs just sent this over to me on an email. If you haven't seen it already, well worth a read. It's right up our street.
Dear Tech Support,
Last year I upgraded from Boyfriend to Husband and noticed a distinct
slowdown in overall system performance, particularly in the flower and
jewellery applications, which operated flawlessly under Boyfriend.
In addition, Husband uninstalled many other valuable programmes, such as
Romance and Personal Attention and then installed undesirable programs
such as Rugby , Football, Sailing and Continuous TV. Conversation no
longer runs, and Housecleaning simply crashes the system. I've tried
running Nagging to fix these problems, but to no avail.
What can I do?
Signed, Desperate
Dear Desperate,
First keep in mind, Boyfriend is an Entertainment Package, while Husband
is an Operating System. Please enter the command: 'http: I Thought You
Loved Me.html' and try to download Tears.
Don't forget to install the Guilt update. If that application works as
designed, Husband should then automatically run the applications
Jewellery and Flowers, but remember overuse of the above application
can cause Husband to default to Grumpy Silence, Garden Shed or Beer.
Beer is a very bad program that will download the Snoring Loudly Beta.
Whatever you do, DO NOT install Mother-in-law (it runs a virus in the
background that will eventually seize control of all your system
resources). Also, do not attempt to reinstall the Boyfriend program.
These are unsupported applications and will crash Husband.
In summary, Husband is a great system, but it does have limited memory
and cannot learn new applications quickly. It also tends to work better
running one task at a time. You might consider buying additional
software to improve memory and performance. We recommend Food and Hot
Lingerie.
Good Luck,
Tech Support
Dear Tech Support,
What can I do?
Signed, Desperate
Dear Desperate,
Lingerie.
Good Luck,
Tech Support
