right, where to start!
Plan would be to run windows XP with 3 GPU clients running.
**B Grade** Abit IX38 QuadGT Intel X38 (Socket 775) PCI-Express DDR2 (MB-138-AB) £68.99
Samsung SpinPoint F1 320GB SATA-II 16MB Cache - OEM (HD322HJ) £40.24
Intel Celeron E1200 1.6Ghz Dual-Core Processor (LGA775) - Retail £39.09
Coolermaster Elite 330 Midi Tower Case - Black (No PSU) £29.89
OcUK 2GB (1x2GB) PC2-5300C5 667MHz DDR2 Dual Channel Kit £17.24
From what I understand the low spec CPU and ram will be fine running just the GPU client. HDD requirements are also very low - I could get a slightly cheaper HDD, but figure that at least 320gb might be useful some where else if I need it to be.
Running XP would mean that I dont need VGA dummies or monitors connected, is that correct? I would want to put the PC in a cupboard with my switch / router / NAS, so no space for monitor really! would leave it running 24/7 and setup some kind of remote access so i could check up on it now and again.
I have found some reasonably cheap 8800GT's, these seem like a better deal than the 9800GT's that OCUk stock. looks like there is little performance gain for the extra outlay.
Zotac GeForce 9800 GT 512MB GDDR3 TV-Out/Dual DVI (PCI-Express) - Retail (ZT-98GES4P-FDR) £86.24 x 3
what kind of PSU will i need for 3 of these cards? bearing in mind the CPU will be barely in use and no accesories apart from maybe a few fans.
any other advice on the above?
cheers.
cheers.
