Continuation of graphics problems.
20 Oct 2002
North West
It's seriously getting silly now. I've had this corruption before, but a driver change solved it. Surely I can update without having this issue? I uninstall properly, so what gives? When the my chip was causing corruption in windows - the GPU temp was 55, surely that's ok?
It's nearly a year old - why would it go now? I can't think of any plausible reason for it to :(. I've just hosted a game of CS:S and ran around on my own for a bit and it was fine.
could be anything mate, could just have been a bad card that didnt last to long
have you oc'd it? flashed a bios (higher volts?)?
Never been flashed nor has it had any voltages altered. If its lasted a year, surely there shouldn't be a problem? Nevermind, I'll see if yet another driver change has helped.
hmm i recently installed a 7800gtx and in cs 1.6 i get a tear across the bottom of the screen, it's still playable but it's just slight seperation all the way across the screen? kind of annoying as 1.6 is hardly graphics intensive!
Well I re-installed the Cat 5.11's last night and its back today :/ - they solved the problem originally when I had it a while back.
Edit: 3dmark 2001 ran through fine :/ - weird issue.
Edit: Just installed on my mum's bf's rig (as ocuk have had his card for nearly 4 weeks now on RMA) and it produces a black screen after say 10-15 minutes of play.
