- 25 Jun 2009
- England
But i REALLY want a rig now, i want a rig with Core I7 before they all go. So if i was to get all the high end specs, but get a basic GPU for now till new ones out, then im sorted and will only need to upgrade to the card i want next month. So thinking of the below spec for now.
Intel Core i7 920 2.66GHz
6GB DDR 1600MHZ memory
1TB Hard Drive
Asus P6T (Intel X58 chipset, SLI/Crossfire)
Windows Vista 64(with Free upgrade to Windows 7)
Antec 900 Case
Thinking of getting a basic ATI Radeon HD 4850 512MB GDDR3. Then when new cards come out next month, just upgrade.
The Motherboard will be ok for new cards won't it? and probably work out cheaper buying the rest now, than getting it all together which the costs will be a lot more with a new card in it.
Would it be a simple thing as just removing the old card and putting the new one in and switching it on, then downloading the drivers? Never fitted anything in a computer for, just hoping it would be that simple.
1TB Hard Drive
Antec 900 Case
reported only last week!
