I'm looking to buy 2 new monitors for my dualscreen setup. I had a look through the TFT sticky, and saw this:
The thing is, I'm now seeing contrast ratios around 10,000, 20,000 and even 50,000! Are these numbers just exaggerations, or has the tech really improved over the last couple of years?
Also, will I notice any difference between a monitor with a CR of 10k, and one with 20k?
Contrast Ratio
The Contrast Ratio of a TFT is the difference between the darkest black and the brightest white. As a rule of thumb, the higher the contrast ratio, the better. The higher the contrast ratio, the stronger the colours will look. The depth of blacks and the brightness of the whites are also better with a higher contrast ratio. When considering a TFT monitor, a contrast ratio of 700:1 is pretty standard nowadays, but there are models which boast specs up to over 1000:1. Be wary of quoted specs however, as sometimes they can be exaggerated. VA panel specs are generally the most reliable and accurate to reality when considering contrast ratio. Some technologies boast the ability to dynamically control contrast and offer contrast ratios of 3000:1 and above! Traditionally, TFT monitors were said to offer poor black depth, but with the extended use of VA panels, as well as new Dynamic Contrast Control technologies, we are seeing good improvements in this area.
