Memphis said:UltraVNC.
Trifid said:I have RealVNC on my computer. It works fine until you try to VNC your self.![]()
ruffneck said:
ruffneck said:
ruffneck said:
ruffneck said:
nellystew said:Another thumbs up for Logmein.
Has the advantage that it only requires software to be installed on the machine you want to control, and you access it through their website.
This means that you could be at your home pc, work pc or friends pc, and you can access it without having to install any additional software.
Trick said:You can do this with VNC too, as long as the machine you're using has java enabled.
