Control Command D - Dictionary
12 Mar 2006
Boarding the Nostromo
Hey, not sure if anyone will know this, it's probably not too hard though, i'm just don't know how to do it.
When a word is highlighted and you press command control D, a window pops up and explains the word, basically a dictionary on the fly. Would anyone know how to reconfigure the keys, i'm finding the key combo a bit annoying, i would ideally like to change it to the right command and L if possible.
Can this be done?
Cheers lads..
Edit. I've found out how to do it, system pref > keyboard > services > look up in dictionary. Although this brings up the full apple dictionary not a window pop up.
Thread can be closed if need be, otherwise, hope it helps someone. :)
