- 14 Mar 2011
Does anybody know of a way to have better control over programs launching at startup? In particular this is the situation:
At startup I have Rainmeter, and OHM (Open hardware monitor)... Rainmeter pulls some information from OHM via a plugin... If OHM hasn't started when Rainmeter tries to access it then it causes an error and I get an annoying popup from the plugin...
So can I somehow make it so that startup always launched OHM first and waits until it has started before launching Rainmeter?
(The only way I could think of would be to write a short Python/powershell script which does this, and add that to startup instead of OHM + Rainmeter separately, but that seems quite a clunky way to do it)
