can anyone reccomend me a good controller for F1 2010
i would consider a G25 but are there any controllers that are worth a shot ?
i am aware that a wheel is the best bet, but a G25 isnt the cheapest option is it.
any suggestions welcome
I assume that you are getting it on pc or ps3 but if you don't want to fork out for a g25 then I can recommend the driving force pro as raikesi suggested. I had one before switching to my g25 and it is a good wheel. Warning though, if you are looking at picking one up second hand they do suffer with pedal spiking problems unfortunately.
Driving force gt (newer version of the driving force pro) is about 80 quid and works fine with pc. A good compromise if you don't want to pay £200+ for a wheel!
