I hate seeing a thread where the OP asks a question and no one provides an answer but decides to give recommendations against the clear request.
So in that respect I'd recommend the Logitech Rumblepad 2 since you can pair that with profiler software to imitate a 360 controller, it's wireless, comes with a receiver, fits comfortably in the hand, cheap on fleabay, takes AA batteries and lasts for ages.
In my opinion the OP would be better off spending just a small amount extra and getting a wireless XBOX 360 controller, a controller that is truly plug and play. No pairing and messing around with extra software, it also comes with a receiver, fits comfortably in the hand and takes AA batteries that last for ages.
The Logitech you recommend doesn't appear to have analogue triggers which are a great help in racing games (if you don't have a wheel/pedals)
Let's be honest £25-£30 for a superior gamepad isn't even the price of a AAA game now!
EDIT: Just seen your previous post and am now confused
I'll tell you this; I don't frivolously throw around money and was in the same boat as you a while ago, so the Logitech Rumble Pad 2 controller was my controller of choice. Inevitably I grew tired of finding/configuring profiles for every single game and moved to the wireless 360 pad.
Trust me, it's absolutely outstanding. Every single game supports it out of the box and for some reason the control layout feels so intuitive for every game. I dismissed it initialy as the price was quite high but it's worth every single penny and now I just feel silly for not buying it sooner.
