Controlling a Network Computer
9 Jul 2004
Rotherham
Looking for a way to control my Fileserver from my PC so i can install programs and change settings etc. Anyway to do this, ive tried TightVNC but it will not connect to the server :(
Any other ways?
Thanks, Ben
Use Remote Desktop...
Enable the controlling of the machine via right clicking my computer > properties > advanced > remote settings
Then on the computer you want to do the controlling, go to
Start > run > type "mstsc" then enter the machine name or IP address.
Voila
Voila
Remote desktop has changed my world...... I can even remote in from my HP 2210 PDA !
I'm currently running 2 servers as I'm in transition... can remote into both at the same time and copy between them....
AD
