In the process of building my new machine i have stumbled upon a problem. One of my aims with my new PC is to be able to control every fan in the case via two fan control 5.25" drives in the front of the case. However i have the problem that the cheap thermaltake fans that come with the case have power connections straight into the 4-pin molex, with only a yellow cable that can plug into the fan controllers for giving an RPM reading, without any real control.
So I have come to the conclusion that i have two options.
1) The easy but expensive method of replacing all 3 of the case fans with better ones that have the right 3-pin or 4-pin connectors that fit into my fan controllers.
or
2) The probably cheaper more time consuming method of re-wiring the fans with 3-pin molex connectors instead.
Now i think i could cope with buying and fitting 3 new fans, but i was wondering if anyone knows what tools etc I would need for the task of re-wiring the fans i already have instead of splashing out on some new ones.
or
