Controlling FAN speed on Speedfan
8 Feb 2004
North West
Recently got both fans working, one a YS-Tech 120mm 105 cfm and a another 92mm side case fan 2500 rpm 55 cfm. The 92 mm fan is currently running at 1500 RPM since connecting it to my motherboard, so its more quiet.
I Was wondering if fan speeds can me manually controlled by speedfan? ive only heard that speedfan controlls the fan speed when temps go up such as when gaming, but is there anyway the fans can be manually set?
Also any idears guys on how to configure speedfan properly?
Is there any other software that i can use to manually configure my fan speeds since speedfan is to complicated to be honest?
