Controlling fan speeds?
27 Mar 2013
Nottingham
What's the best way to control case fan speeds? Got all my fans hooked up via 4 pin PWM. Wondering the best way to control them? Is it bios or any decent programs for the job?
Obviously without a fan controller. I will eventually pick one up one day but got more important upgrades in between.
Gigabyte's Easy Tune makes the setting from windows so you don't have to go into bios, but it is bios that is actually dong the controlling. You can remove Easy Tune after setting the speed curve and curve remains the same.
