- 26 Dec 2013
- 404 Not Found
Is there anyway to get 1 set of 4 fans to speed up/slow down depending on if the GPU or CPU temp is increasing?
These fans are on a radiator that cools both the CPU and GPU. So I can't just plug them into the CPU header as if I use GPU processing and not much CPU, the fans won't speed up to cool the GPU.
My motherboard is an Asus Maximus VII Impact.
It only monitors either CPU or GPU, depending on which you have selected. Just ran Prime95 to get some heat in the CPU, not the GPUs and my fans stayed at 40% until I clicked to monitor CPU temp, then it ramped them up, then I clicked back to GPU, and the fans came back down.
