there's recently been an update to the Hive skill/commands on Amazon Echo
before the update I used to say 'Echo, heating xx degrees xx minutes' to boost the heating or 'Echo, switch on the xxxxx' to switch on a plug
after the update if you say anything related to Hive it now says 'You have Hive enabled, do you want to open it'...then you need to reply... it opens then starts giving examples of what you can do 'I can boost the heating' etc etc
but not every time...seems random whether it just works as it was previously or if it has to go through the 'You have Hive enabled, do you want to open it' stages
any ideas on how to avoid the 'you have hive enabled.....' part? and just use the commands that used to work
cheers!
cheers!
, so need to say thermostat instead of heating...so have changed the thermostat name to heating and all back to normal now!
