Hi all,
I currently use Fractal Design Define R5 as a case, and my current fan setup is:
1x FD Fan at rear
1x FD Fan at Front
(These were already fitted in this case when I bought it, and I haven't touched them)
2x CPU Fans (2x Fans around a massive heatsink - Noctua)
1x GTX 1080TI (Fans only turns on when it is in use)
While I am not Gaming, all the fans are running apart from the GPU.
I have the case next to my legs, and it gets really hot when I am Gaming (like within the first 10 mins, it becomes uncomfortably warm
Firstly... Are all the fans required to be on, while the computer is not in use? The case ensures pretty good sound proofing, but if I can turn the front and rear fans off while I am not Gaming, it should be even quieter. How would I go doing that? (I.e Having the fans turn on and off when required).
Secondly... Is there anyway to stop it getting so hot next to my legs when Gaming? I wonder if I'm just going to need to move it from underneath the desk to on the desk...
Any advice is greatly appreciated
Thanks,
Marky
1x FD Fan at rear
1x FD Fan at Front
Thanks,
Marky
