Controlling Phone From PC
10 Jun 2003
Nottingham
Hi everyone,
I have an w810i which is connected to my works PC via USB cable. I was wondering if there is any software in which I could control my phone from the PC?
Cheers
must be, but i've not owned a SE since the T68i or something so i dont know'
'cause
motos - motorola phone tools does it
nokias - their inbuilt bloaty software does
so maybe they bundled software?
Origin said:
Have a look at Floats Mobile Agent I think it will do what you want it to. :)
EXCELLENT PIECE OF SOFTWARE & FREE! New version/updates (after installing use the update feature), keeps all your SMSs even after you delete from phone!
Been using it for about 2-years now with a T610 then k700i (current phone) :D
