Controlling RGB AIO fans through CPU FAN/OPT and rgb hub?
31 Dec 2020
Hi, I'm really stuck and have done lots of research but still not found a solution. I have just bought a 240mm AIO cooler which has the pump built into the radiator and is SATA powered. It comes with RGB fans which can be either plugged into an RGB header on the mobo or it can be used on an RGB controller (which is supplied ) in case you don't have the header (I don't have an RGB header). I don't really like the fans but have 2 other spare RGB fans that match the rest in my case , these are connected with an RGB fan hub (also SATA powered) that controls both the fans and lighting on the same header.
Now here's my problem, I know I need to connect the 2 AIO fans to my CPU FAN / OPT but how do I achieve this through the RGB controller in order to get the lighting and fans to run at the speed of the demand of the CPU?
The motherboard is ASUS Z170 PRO GAMING.
The AIO is ANTEK KUHLER H20 K240 RGB.
The RGB fans and hub can be found here...
https://www.google.co.uk/search?sxsrf=ALeKk01S1sW7Zi_LfVlEpERlGDI2Fe7SgA:1609415980328&source=hp&ei=LL3tX5GCEqmZlwTMp6DwBA&q=cd1225l12fa&oq=&gs_lcp=ChFtb2JpbGUtZ3dzLXdpei1ocBABGAAyBwgjEOoCECcyBwgjEOoCECcyBwgjEOoCECcyBwgjEOoCECcyBwgjEOoCECcyBwgjEOoCECcyBwgjEOoCECcyBwgjEOoCECcyBwgjEOoCECcyBwgjEOoCECcyBwgjEOoCECcyBwgjEOoCECcyBwgjEOoCECcyBwgjEOoCECcyBwgjEOoCECdQAFgAYL0RaAFwAHgAgAEAiAEAkgEAmAEAsAEP&sclient=mobile-gws-wiz-hp#imgrc=y4lHLjUncGrI6M
Any help is appreciated
Don't most RGB controllers have a RGB in and a PWM in connector that the hub then shares to all the outputs. If so, take your Cpu header and connect it to the PWM input of the controller then that way the controller will set all the fans to what it receives from the Cpu header signal.
Thanks for the reply. I'm guessing then that might be the socket next to where the molex connector comes out from. I don't think I've got a cable for that .Will see if there is one in the box of the cooler.
