Controlling Three Fans At Once
26 Aug 2003
Ringwood, Hampshire, UK
Hi,
Is there a way I might control three 120mm fans from a fan controller at once, i.e. three fans attached to radiator? Can I simple mod the cables to attach to one socket on a fan controller so when I change the setting on that socket it slow/speeds up those three fans together? Sorry if that sounds stupid, I know little about low voltage modding.
Yes it'll divide the power but 6v is still usefull, Iam not sure if 4v would work out as well.
I quite like the idea of a master control for when you know your'll need more or less cooling definetly but the only effective way Ive seen is to use a software/motherboard fan control setup and they are rarely well made unforunately
If you do that (all on one channel), make sure you have enough power per channel. I use the Sunbeam Rheobus which is one of the best fan controllers out there - not necessarily for looks or anything but because it offers a whopping 20W per channel. This means you can even run pumps from the fan controller - should you so wish. An excellent fan controller - as I'm sure people would contend at Xtremesystems.
