24 Jul 2015 at 12:31 #1 jfish jfish Associate Joined 24 May 2011 Posts 216 I need to migrate a few virtual servers on ESXi 4.1 to Microsoft HyperV 2012 R2 - any free tool available to convert the virtual disks.
24 Jul 2015 at 12:36 #2 gman1981 gman1981 Associate Joined 23 Jun 2009 Posts 63 Not used any, jsut did a quick sarch for VMDK to VHD tools and found this one: http://www.2tware.com/product/6/2tware+convert+vhd+free
11 Aug 2015 at 19:00 #3 Worthy Worthy I haz 4090! Don Joined 18 Oct 2002 Posts 8,230 Location Manchester Are you using VMM? Or NetApp storage for that matter?
11 Aug 2015 at 20:08 #4 traveyb traveyb Associate Joined 25 Jul 2012 Posts 1,272 I've used a couple before (will try and dig out the names) but make sure to make a copy of the disk first as it can go a bit t*t's up!
11 Aug 2015 at 21:32 #5 tris179 tris179 Associate Joined 11 Jan 2012 Posts 73 I think Starwind do a V2V converter... Never tried it tho....
21 Aug 2015 at 10:53 #6 swain90 swain90 Associate Joined 7 Aug 2012 Posts 949 Wouldn't it be easier to do a clone of the disk rather actually converting it. Clone the drive to a network store, then when you've created your new disk restore the image from the network?
22 Aug 2015 at 19:57 #7 Wilderbeast Wilderbeast Associate Joined 18 Oct 2002 Posts 2,365 Location Manchester I've used the 2tware converter on quite a few with great success.
