Convert word doc into power point presentation? HELP!!
27 Oct 2002
London
Is there a quick way to convert a word doc into a powerpoint presentation keeping formatting such as bullet points.
Thanks
You should be able to go to file > open in powerpoint and open the desired word file. You will however need to make sure that the appropriate converter is installed.
Btw you should have posted this in the software section.
Thanks
File
Send to
Powerpoint
is the official way from in Word with your document open.
