Converter needed for case fans.
5 Oct 2004
Notts
I've just built a system based around the ASUS P55 Intel board. This comes with 2 X 3 Pin power connectors and 2 X PWM connectors.
I have a Noctuca with two fans and two case fans so I've hit a problem.
Are there any converters that go from SATA/Molex power to 3 Pin Fan power?
If i am reading your post correctly you have 4 fans and 4 fan headers on the MB.
This being the case then you dont have a problem.
Standard 3 pin plugs will fit on PWM connectors.
Mmm, 3 pins are pretty much a 4 pin with one side pin whacked off.
There's a guide rail thing on one side which makes sure you stick it onto the correct 3 out of the 4 pins on a PWM capable connector.
No longer relevant given the above, but molex to 3 pin power are readily available. I've not seen sata to 3 pin power, but can't see why they wouldn't exist. You can also get Y splitters, though they may damage the motherboard.
