If this is the case then get an architect in to look at the house, explain what you want and let them loose. I am sure they will be able to come up with a much better plan for some sort of wrap around extension that will integrate better with the house and still leave you a garage.thanks for the advise. I’m not trying to build an extension on the cheap, but work out what I should put to the side to do it properly. Cheap is not in my vocabulary
There aren’t many houses over 2,500 sq ft in the area we want to move to for work, except new builds which are a no no.
Got a floor plan? Someone here could probably give you a starter for ten!
