converting avi to mpeg, i need help
7 Jun 2003
Gloucestershire
im trying to convert a .avi file into dvd format using a program called AVI2MPEG2 v1.24
now... i want this to go on a DVD but how do i limit the file size (so that it doesnt go over DVD disc size) and am i doing anything wrong when it says its going to take 22hours to encode (and rising)!?!
ive been trying to use a guide but its very brief, everythings set to pal, resolution at 720x576 (correct?)
cheers for any help, my first attempt at this :P
would have put this in optical drives and storage but seeing as its half and half of software and hardware this place is a bit more active :p
Wow, it's been a while since I've seen you about bru, how come you're not on MSN anymore? :p
Use a program called WinAvi. A lot better to use. Can also limit the file size. ;)
ahhh much much better program, limits the size and goes a good 15-20 times faster, cheers dude :D
