Converting mp3s BACK to .cda
Permabanned
17 Jan 2006
Haskins
Standard CD tracks on files are .cda's arent they!?
If so, does anyone know of some software (other than WMP) or Windows that can convert MP3s BACK to a decent quality .cda!?
You know when you write a cd with MP3s you get the option to either create an audio CD or a data cd, and for mp3 you choose 'data'.
Well I want to create a normal CD again, so..........any suggestions, as I find that Windows muffles the files (and for some reason makes them stupidly large again!?)
Thanks
MP3's will burn back to normal cd's when you use the audio cd option in nero and every other burning program i have ever used.
Sorta answered your own question :p
Just choose to create an audio CD, your .mp3 files will be converted automatically.
No, because I want something that doesnt result in such a loss of quality.
Sorry if I didnt make sense originally
the sound quality is lost during the encoding process TO mp3. there is no way to get that back.... :p
cd files are not .cda's. .cda's are simply links to the tracks on the cd, shortcuts if you like. Check the size of them - they are only a few bytes.
No I know. But an MP3 sounds signigifcantly better than an MP3 thats been converted BACK to a normal audio file.
Why!?
no you dont
Why!?
because you are converting a lossy format to a wave file?? any conversion of a lossy format will only make it worse...
you shouldn't lose anything noticeable though. surely mp3>wav would create an exact copy?
no its a conversion, how can it be exact?
you take a 4mb lossy format mp3, turn it into something with a high sample rate and something that is 30-40mb in length, filling in gaps as you go along, and you think it'll be identical? the difference you'll end up with depends on the quality of the decoder and the quality of the mp3 to start with.
If quality is that much of an issue, copy the cd tracks next time.
cd' audio tracks are basically 44.1khz 16bit stereo wav files. They take up a lot of room mate. 1 minute is roughly 10mb. you have to convert mp3's to that file type to write an audio cd
