Converting my system into a mATX
4 Dec 2006
Hertford/Portsmouth
Hey all,
Currently I have my system in a lian li PC7, specs are in my sig.
The mATX case I want to change it into is the silverstone sugo SG01,
I think then all I have to change is my motherboard and my CPU cooler.
Which would you guys recommend ?
Im not interesting anymore in overclocking, so thats not a bother.
Maybe just a motherboard with abit of room to upgrade the CPU and graphics card, maybe PCI-E 2.0 ? I dont know much about PCI-E2.0. so you guys can advise there..
Budget wise, I dont wanna spend all odds, the cheapest Ive found for the sugo is already 88 quid !.
Thanks for any help !
Slinger
I know you said no overclocking, but why not? It would be a travesty to not overclock that processor, especially as you should be good for 3GHz.
I'd get the Gigabyte G33M-DS2R and the Silverstone NT06 cooler, and that way you'd be set for a good overclock. With that graphics card it will really help!
And I don't think there are any microATX PCIe 2.0 boards yet - you'll have to wait for G43/G45 for that.
Thanks for the help,
I said no overclocking cause ive had problems with tempretures and my E6300, but I suppose if I have the ability the overclock with a mobo I get, Ill push it up abit.
I take a look at the mobo you suggested !
Oh and the cooler you suggested, is it the "lite" version thats best ?
thx again
ahh, might have been up for some kind of deal if you were but im not a great fan of ASUS there support leave a bad taste in your mouth.
