converting program
4 Nov 2010
Hi everyone.. can anyone recomend a avi to dvd convert and burn all in one program.. i use convertxtodvd but was wondering is there anything else out there..Thanks...John
Depends..
How long is the avi?
How fast is your cpu?
Which program are you using?
Suck it an see!
I used DVD flick. It took ages but the software is free and the interface is good.
I usually use WIN AVI 8.0. Its an old piece of software, no longer supported but works well and with my i7 I can convert a 700-800MB Avi to DVD in 2 mins max. 700+ Fps.
