Hey guys,
I was hunting around for a new case in an attempt to improve airflow and make everything a bit less cramped inside my case. I eventually settled on the Phanteks Enthoo Primo, but my research also turned up some really nice looking hard tube builds using this case. I needed a new project, so I was thinking of turning my current (soft tube) loop into a hard tube loop.
I haven't tried hard tubing before, but I was looking at a setup roughly like this. The component positions aren't 100% accurate, but the flow/chain hopefully are .. so PUMP/RES > CPU > RAD1 > GPU > RAD2 > PUMP/RES:
Here's what I already own:
EKWB 360mm Rad + 3x Vardar fans
EKWB CPU Waterblock
EKWB Radeon R9 390 Waterblock
EKWB Pump/Res Combo
EKWB Fixtures and Fittings!
Here's what I "think" I need to make the swap:
EKWB 240mm Rad
EKWB HD PETG Clear Tube (x3)
EKWB HD 10/12mm Adaptor (x10)
And I was also thinking of getting this to make life easier - XSPC PETG Easy Cut/Bend Toolkit
First question ... have I overlooked anything obvious? I am essentially just adding an extra 240mm rad into my existing loop, and changing everything to hard tubing instead of soft.
Second question ... the cut/bend kit doesn't come with a heatgun. Is it actually 100% necessary, or will a hairdryer do the job?
Third (and final
) question. What parts would I need to add a draining pipe into the system (as crudely shown in my image above)? Some kind of "T" piece and a valve? I am not too sure what to look for here.
Thanks very much for any help. I'm sure I'll have more questions once I think of them
Cheers, Ori
EKWB CPU Waterblock
EKWB Pump/Res Combo
EKWB 240mm Rad
Third (and final
) question. What parts would I need to add a draining pipe into the system (as crudely shown in my image above)? Some kind of "T" piece and a valve? I am not too sure what to look for here. Thanks very much for any help. I'm sure I'll have more questions once I think of them
Cheers, Ori
. But my shopping cart would look something like this:
