Right, Chris1712 kindly gave me a disc that converts XP to Media Centre Edition without a reload... Sounds good, I had just reloaded my PC so I thought I'd just try MCE...
The disc is a BartPE disc.. And has 4 steps:
1. Installs .Net Framework
(reboot)
2.Installs MCE 2005
(Reboot)
3.Pre Rollup2
(Reboot)
4. Rollup2
(reboot and done)
Right, I go through the steps, But when I get to the Rollup2 stage (Step 4)
it says "Can only install on MCE 2005"
It's like now half installed as I have the blue energy theme but the Media centre bit doesnt work...
Chris Installed it perfectly using the same software config as me (XP Pro Corp, Same Disc)
Any Ideas how to get this working + Has anybody else had this problem at all??
My system (for reference) is:
AMD Athlon 2500+
1.5Gb (3 x 512mb) DDR400 RAM
Nvidia 6800GS 256mb
1 x 120gb SATA HDD
1 x 40gb IDE HDD
I don't think it makes any difference though...
Cheers
(reboot)
2.Installs MCE 2005
(Reboot)
3.Pre Rollup2
(Reboot)
4. Rollup2
(reboot and done)
AMD Athlon 2500+
Nvidia 6800GS 256mb
1 x 120gb SATA HDD
1 x 40gb IDE HDD
Cheers
