Cookie problems
18 Jan 2007
Land of the Scots
Can someone, do me a favor and go to http://ufopedia.csignal.org/ do a search in the box for "autopsy" and tell me what you get.
The search script I'm using is javascript based and passes the search variable to the results page via a cookie. The search works flawlessly in the sub categories, but not on the main site.
Just want to test if a fix I've done has worked,
0 result(s) Your search did not match any documents.
Make sure all keywords are spelt correctly.
Try different or more general keywords.
edit: Firefox tells me I have a cookie value "autospy" with key "d"
It seems Google Analytics was interfering with the cookie, good thing I don't really need it on the site :)
