After trying a number of browsers today I landed up with an irremovable tracking cookie. No big deal really, but when I ran Spybot it found 2 entries for Hitbox.
After erasing them and re-booting they appeared again. Tried Malwarebytes and that didn't even identify them.
After a search for removal sotware (avoiding the dodgy ones) I happened to find "Mil Shield". That removes all cookies, temp. internet files and a host of other files. I gave it a bash and when I reran Spybot, Hitbox was removed.
That says to me that the IE/Options/Remove Cookies etc. facility does not remove all.
If stubborn cookies like Hitman can be removed by a utility like "Mil Shield",are there any other out there that I may want to try. FRee or paid.
I would buy that one but am reluctant to use credit card for a small amount to a US site. Silly maybe I know, but that's me.
Any others that you know of. Thanks.
. It's very light weight and you only need to run and update it every couple of weeks. It works by adding known tracking/bad cookies to your browsers "block" list
