Cooking a gammon joint
Status
Not open for further replies.
14 Jun 2009
I've got a 2KG Gammon joint here, unsmoked. However, I'm unsure of how to cook it.
A lot of recipes all agree that the gammon should be left in water overnight to remove the excess salt. That's where it ends :p
Some say boil the gammon for an hour or so, then cook and glaze but some say straight in the oven.
So from personal experience, what method should I use and what glaze would you reccomend?
Thanks.
Put some oil in the top of it then rub some salt in to the top of it. Then put a little bitof mustard on the top. High heat for 30mins and then 1hr 30mins on gas Mark 6. Happy feeding!!!
Status
