Cooking a whole chicken? what else to do with it?
Caporegime
1 Nov 2003
Lisbon, Portugal
Hi all,
Most weeks I cook a whole chicken from Tescos, when cooked I allow it to cool then strip and carve it then mix the pieces with pasta and salad and bung it in a container, this is then lunch for me and my sister for the week.
The chickens are typically 1.5kgs and take roughly 90mins to cook in the oven, I'm wondering if theres anything else I can do to the chicken to change/improve the taste (it tastes damn good anyway)
Maybe season it? marinate it..something?
I'm not sure, I'm pretty new to cooking and experimenting so please fully explain any suggestions :) - Spicy or sweet, whatever flavour really, just something so its not completely bland chicken afterwards! (even if it does taste good anyway)
Many Thanks,
Jake
Lemon and Thyme & Garlic.
Crush Garlic, Thyme with some butter together, stuff that under the skin in the breasts
Cut the lemon in half, stuff it inside the chicken
Stick the chicken on a low rack in a baking tray. Put a strip of bacon on the breasts to stop it drying. Baste often.
if you like crispy skin (i know i do :D), rub a small amount of oil onto the skin so that it becomes sticky, and then sprinkle with rock salt, a small amount of chilli powder and plenty of paprika, and a bit of garlic to taste too.....amazing flavour :)
I done one in the barbecue the other day on a bed of veg in a disposable cooking tray, very tasty.
Also, make chicken paste sandwiches with leftover chicken. I think the way to make it is..
Chicken
Chives
Ketchup
Salad cream
Splash of vinegar
Blend
Make soup with the leftover carcass. :D
Definately, or even just stock. Simmer it for a couple of hours with loads of water, an onion, carrot and bit of celery. A bay leaf and a sprig of thyme don't go amiss. Then make soup or amazing risotto. Great thing about doing this is that you really get the bets value out of a chicken, and it will taste a million times better than any bought stock. You can even save the stock and use it to make gravy for the next time you cook a whole bird :)
Buying my chicken tonight, going to give the beer can method a go :)
Going to do the same method as described but use Grolsh as my cooking beer of choice!
last week i done a chicken marinated in nandos sauce for 24 hrs, and it tasted great
spatchcock (butterfly) the chicken
but i dont cut it in half.
and it cooks in 50 mins (as its flattened)
Right boys its in the oven! My first chicken, arse-beer style....doesn't sound very appetising does it :p
In the rub I added in chillis :) - Be good to see what its like :D
Good shout there Raymond.
I'd say:
Shove a half clove of garlic and a knob of butter under the skin up to the front of the breast. Put lots of thyme all over it too and give it a smear with olive oil and butter. Bit of rosemary never hurt anyone either. Stick garlic and herbs in its bum. Put one rasher of bacon over each breast. Shove in the oven.
Also:
Get a bit of chilli and lemon into the same procedure as outlined above. Get some chorizo in with your potatoes and in its bum.
Another:
Get your casserole dish/ heavy pot. Butter and oil in. Whole/half shallots in (maybe 8-as many as you wish) halve an onion. Roughly chop a carrot or two. Heat high. Brown off the chicken all over and shallots and onion. Throw in the carrot bay leaf some thyme. 150/200ml chicken stock and a large glass of wine. stir. seal with foil. put the lid on. put in oven for an hour.
Done.
