- 3 May 2004
- Kapitalist Republik of Surrey
I've been holding out for a bit before I post this because it's taken a bit of experimenting and practice, but I think I'm ready so here goes. If you read this section much you've probably seen that I cure my bacon and I've been doing it for a few years now. I've wanted to try curing some ham but it's a much bigger commitment because it's a big hunk o' meat and takes a bit longer. If you can do bacon and understand the curing so you can make it not too salty, then this will be a pretty easy transition. Essentially, the difference is that ham is wet cured and cooked, while bacon is dry cured and either eaten raw or fried.
Here's some I made earlier, ready to stuff into a sandwich:
You need:
Pork
Salt
Sugar
Saltpetre (you can get it on eBay or in your local chemist)
Water
Large container to cure it in
I got lucky with the meat and picked up a 2kg hunk of pork reduced right down. Ideal for the early days when you're not 100% confident it's going to work:
I took the skin off and trussed it back up to make it a convenient shape again. The skin can be used to make pork scratchings so don't throw it away:
Now you need to make a brine to cure the meat in, which is made up of salt, sugar and saltpetre:
You need:
Pork
Salt
Sugar
Water
