Cool 3D Printed PC Nerd goodies!
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
Hi
I have printed this home lab rack mount, all in ABS for great strength.
Currently housing my 2.5gigabit switch and pass through module that I designed myself using UGREEN RJ45 couplers.
I plan to add my home assist hub, currently in a pi, but I plan to upgrade to a miniPC for it, and a touchscreen IPS panel for monitoring and stats etc.
Just added a Philip hub Bridge 1U bar.
Nice work, did you design the frame? That ABS looks really clean. Out of interest what's your method for the heated inserts? I was using a Dremel press with an attachment but it was a faff so recently just having to free hand them.
I just used a soldering iron to heat the inserts and they pushed in easy. Took about 20 seconds per insert, so it does take a bit of time.
I was tempted to try just resting a clothes iron on the inserts and once they start heating up remove it and push them down together using a piece of wood, and do them all at once, but didn't want to risk burning the ABS.
