cool-it fans
14 Apr 2010
swanley,kent
hi,ok i've installed an eco alc coolit in my antic 300.it's cooling an i7 930 clocked to 4.0ghz.i've just ordered 2 Scythe Ultra Kaze 2000RPM 120mm Case Fans to mount on the rad.which way around would you suggest,both pulling cool air into the case or pushing hot air out?.i have 1 of the tri cool fans mounted at the front pulling air onto the hard drives and the other one will be mounted at the front too when i get these fans.also i will be running a Yate Loon D14SM-12 140mm Case Fan 1400rpm pulling hot air out the top of the case(at least the noise will drown out the missus when she hoovers).
I have the eco as well but with 2 apaches on it. I found that the coolest setting is having it pull air into the case
I have the cool it eco alc with one fan,a Scythe Kaze Jyuni 1900RPM Slip Stream pulling air into the case it works better for me. Ive tried it the other way around,but it was not as good.
