competed - 'Cooler' new look for an old System
Hi all,
quick summary of my setup
Asus A7N8X-E Deluxe
Athlon XP 3200 Barton
Zalman CNPS7000A CPU Cooler
Radeon 9800Pro
Audigy 2
2 * 512Mb Crucial PC3200 DDR
NEC ND-3520A DVD-RW
PlexWrite CD-RW 16/10/40
1 * Maxtor DiamondMax Plus 10 200Gb SATA 8mb Cache H/D
Enermax Noisetaker 485W PSU
Full tower case (can't remember name but iss bright blue)
Basically cooling is as above and both sides left off the case (which sits under an open window).
Just recently this has proved to much for the old girl so I'm looking at an upgrade (currently at 42C idle).
I quite like the look of the Antec Nine Hundred Ultimate Gaming case and read some good writeups on it.
Would this be ok with my rig and with a future upgrade to a core2duo in a couple of months? I did read some posts about people saying there wasn't much space inside.
Any opinions ?
Also, would the Asrock 775DUAL-VSTA motherboard and an Intel CPU Core 2 Duo E6600 be good as a straight replacement for my m/b & cpu (is there a new version of the E6600 coming out soon?).
Thanks in advance for any advice, especially about the case.
Willow
P.S. I don't plan to overclock at all.
Hi all,
Asus A7N8X-E Deluxe
Radeon 9800Pro
Audigy 2
NEC ND-3520A DVD-RW
Any opinions ?
Willow
), the Antec would be towards the top end limit. What I liked about it was the fact that it came with the fans included so I didn't have to buy any extra to the case.
