- 4 Jun 2010
Hey guys,
So i bought the very first thing for my new loop! It says this on the sticker
Now for some questions
1) Can I use this with Mayhems dye?
2) Can I use this with Mayhems dye AND a silver kill coil?
3) What do you find is the best way of mixing dye? Pouring into a smaller container and then mixing?
I am thinking of mixing this with some red dye and then putting it into a loop with a silver kill?
Thanks
Freddie
BATTERY TOP-UP WATER,
De-ionised for use in lead-acid batterys
Use in engine cooling systems to help reduce scaling and corrosion
Also suitable for irons, lava lamps and air-conditioning units
Thanks
Freddie
