Coolant on GPU
22 Apr 2011
Nottingham
Hi! I had a leak on my 3 x 1080ti custom loop rig, Which resulted in all 3 GPU's getting some Mayhems Pastel on them. After a good clean up, 2 are fine and working 100%, 1 is not.
It has some sort of power issue, The display it outputs is fine and it shows in control panel as all working but when its put under load it bounces around from 23%-27% power and will not go any higher so it's pretty much useless :(
This card did get the most coolant on it of all 3 but mainly in one place on the PCB, I've highlighted in red which area got wet in the picture below
Currently, it's sat a few inches away from an Antminer being blown constantly by hot air directed at the bit highlighted in red.
Any suggestions welcome, Should I put it in the oven for a bit? If so at what temp and how long for?
Thanks!
