- 22 Sep 2020
Hi all have a Q about is there any way it can go off? And if I use a sieve to stran bits out of it I have EK blood cryofull
Typically most coolants are distilled water + gycol and some other anti-corrosive or biocide. If unused and sealed in cool/dark it's not going to go "off."Hi all have a Q about is there any way it can go off? And if I use a sieve to stran bits out of it I have EK blood cryofull
You shouldn't have "bits" in your coolant if you've cleaned your radiators properly before you even build the loop.Hi all have a Q about is there any way it can go off? And if I use a sieve to stran bits out of it I have EK blood cryofull
Papper fell apart when I wipe leak upYou shouldn't have "bits" in your coolant if you've cleaned your radiators properly before you even build the loop.
I've noiced my loop temp on my loop sensor keep going up my cpu and gpu temps are good I have to turn ac on to keep under control dident noice this be for just wonder if there issue with coolant?Typically most coolants are distilled water + gycol and some other anti-corrosive or biocide. If unused and sealed in cool/dark it's not going to go "off."
If it's coloured it might potentially start to separate as it's a form of suspension which might increase the chance of clogged fins without inspection/annual maintenance.
It's only just bin filled lolMore likely you have some clogging in some block. How long ago did you check/empty the loop?
