Coolant Replace Frequency
25 Nov 2015
UK
I'm using Mayhems UV green coolant on both loops and have noticed the clear flexi tubing is suffering from UV damage and intend on replacing it. I was also planning on re-positioning the filters so while I was at it, it occurred to me if its worth flushing and replacing the coolant - given this is Mayhems with all the biocide goodness, is this necessary?
The system has been running for 18 months with no problems. I also have silver coils in each res
Replacing the coolant isn't much of an issue, but does anyone recommend a complete strip down and thoroughly clean the blocks? This is a large system and will be a huge job so I'd rather not!
Aesthetic opinions - the PC is of a very green theme! What would making one of the looks UV white look like!? I like the idea of differentiating the two
Thanks in advance
I replace mine every 6 months.
I clean the blocks at the same time.
I dismantle Both GPU blocks and CPU Block and clean with Rubbing alcohol.
Then rinse with distilled.
then i use the mayhems blitz system.
Then rinse with deironised water.
Then refill.
keeps it going strong. the Gunk can really fill up over time
