I wasn't thinking straight yesterday while i was messing about with bits in the car. Noticed my coolant had gone down a bit so i decided to top it up..as you do!
Anyway, I got my bottle of anti freeze which i haven't used in yonks and mixed it in with some water to a 50/50 ratio as it says in the manual (maybe half a pint glass worth or just over) and then poured it in. , i then realised that it was infact erm..ready mixed already
So i've probably now lowered the coolant ratio to maybe 30-40% as it still had a fair bit in it anyway. Should i be fairly bothered and maybe even fork out for the coolant to be emptied again and replaced? Or I could go and buy some non-mixed anti-freeze and try filling it up with it to bring it nearer that 50/50 (coolant+water) again with some educated guess work? but then i'm mixing loads of different coolants together without any idea if this is a problem or not?
I Feel a bit daft, whats the best solution? Theres probably about 1/4 of a pint i could still fill up with non-ready-mixed coolant if i was to go down that route to try and get it nearer the 50%.
I must learn to read the bottle....
stupid stupid stupid stupid stupid
		![[TW]Fox](/data/man-of-honor/2009.png)
